跳转到主内容
这是iPad mini 3(型号A1599)Wi-Fi版本的维修指南。这款iPad在2014年10月6号作为iPad Mini Retina屏版本(现在也做iPad mini 2)的新一代被发布。
61 个问题 查看全部
New home button installed but not working
I had a customer come to me with an iPad Mini 3 with a cracked digitizer and snapped LCD. The home button flex cable was also snagged in the damage and needed to be replaced.
I reused the spacer, gasket and bracket when installing the new home button. However, after installing the LCD and digitizer, the home button isn't responding. I've taken it back apart and reseated the home button flex cable but haven't had a chance to test it yet.
Is there a contact on the home button bracket that needs to be lined up with the home button on order for it to work?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello!
If it does not work, it is likely that the flex is damaged. The fingerprint will never work, but the home function should do it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bill Shannon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 74
