跳转到主内容
The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
[Solved] Nexus 5 Screen is not working properly!
Hi,
I am not able to understand why my Nexus 5 screen doesn't work properly. It seems that the phone is working as I could hear some notifications. What could be a fix for this problem?
Update (01/20/2018)
Changing the flex cable solved this problem!
Thanks guys for your comments.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi @mgupta70 ,
Has the phone been dropped or gotten wet at all?
完成的
Hi,
The phone hasn't been under any water or physical shock/damage.
Still I am facing this problem. And it is not a software problem, I believe. I tried all sorts of resetting techniques.
I am not sure what to repair, the flex cable or replace the LCD/touch assembly entirely. Any help in this matter is appreciated!
完成的
添加一条评论
1个答案
已选择的解决方案
Hi Mohit @mgupta70 a screen just going bad doesnt happen very often without a catalysis . SO lets assume the worst and start to tear it down as if we are going to replace the LCD They can be purchased onebayfor as cheap as 30 dollars This guide can help with the teardown
Nexus 5 LCD Screen & Digitizer Assembly Replacement
But as were not sure this is the whole problem examine the logic board closely as you tear it down . Look for corrosion or discoloration .Next make sure all cables are connected securely and correctly as you disconnect them. Look for rips or tears in ribbon cables check for cracks in any folded ribbon cables. Check for any changes in color and or burn marks . If all seems fine then proceed with the screen replacement . Hope this helps
这个答案有帮助吗?
得分 2
2条评论:
Thanks for your comment!
I have ordered a flex cable first to try and fix this issue. I will do a complete teardown as you suggested and look for faults in case I am not able to solve this problem by just replacing the flex cable.
Thanks a ton!
完成的
Hi @mgupta70 ,
This link may also be of interest to you. Read the last post at the bottom of the page.
完成的
添加一条评论
添加你的答案
Mohit Gupta 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 3,105
