跳转到主内容
加入维修社区 - 创建账户
Sony M-430 Microcassette-Corder can record and play back audio. The one-touch recording and two-speed record/playback and automatic shut-off makes this ideal for on the go recording. Model number M430.
Can I fix the speakers in my Sony m 430 microcassette corder?
I barely found this sony m-430 microcassette-corder and it works for the most part except the sound quality. When I play back anything I’ve recorded it’s mostly just faded voices with an overpowering static sound. Anyone know what I can do? Or is it time to give up? Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Try cleaning the pickup head and see if this improves the audio quality.
Use a Q-Tip moistened with IPA 90%+ (Isopropyl Alcohol - available at most pharmacies).
It may also be a microphone problem but you would need to do testing of the circuit to try and find out where the noise was emanating from to prove this was the case.
Here is a link to the ifixit Sony M-430 Microcassette-Corder Microphone Replacement guide. As the microphone is a sealed unit it most probably cannot be repaired and would have to be replaced if it was the cause of the problem.
这个答案有帮助吗?
得分 1
1条评论:
thank you so much for the help!
完成的
添加一条评论
添加你的答案
Melissa Castro 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 415
