跳转到主内容
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
Why does my replacement touchscreen not work?
I have replaced my screen, metal back plate and home button. The phone works and the screen is able to display stuff however the touchscreen does not work. Am i missing something or would this indicate that I received a faulty screen?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Every time i've either had or seen it happen its been plugged in improperly. So I would say check the plug before getting new screen.
完成的
添加一条评论
2个答案
Make sure you have it plugged in right. And test you lcd and screen first so you know that your new one works before you put back together. Everytime its happened to me it was plugged in improperly.
这个答案有帮助吗?
得分 0
添加一条评论
Double check all the screen connections carefully. If they are properly connected and you still don't have any touch functionality, send the screen back to where you bought it from and get it exchanged for another.
If the replacement screen does the same thing, it could be a defect with the actual connection on the logic board which the screen connects to.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kamil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 105
