Does MacBook Air 11" 2015 share all parts with 2013/2014?
Aside from logic board, are all parts common between 2015 and 2013/2014 MacBook Air 11"? And if so, does that mean a 2015 logic board will work in a 2013/2014 MBA?
I haven't found many details online but as far as I can tell all the other parts are the same so the boards should be interchangeable.
Update (01/11/2018)
Judging from IFIXIT and some other online sources (same means identical or reported to be compatible):
- Bottom case: same
- Top case: same
- Battery: same
- I/O board: same
- I/O board cable: same
- Display: same
- SSD: same
- AirPort card: same
- Trackpad: same
- Fan: same
- Upper case cable: same
- Speakers: same
- Screws (for what it matters): same
- Heat sink: same
- Camera: same
- Battery: same
- Clutch cover: same
I think that is all the parts?
6条评论
Well I didn't expect you to go that far ;-} You only needed to worry about what plugged into the logic board.
由 Dan 完成的
Thats pretty interesting! Good catch!
由 Aiden 完成的
I agree that the externals are essentially the same but I would be surprised if the boards were swappable: (1) the later chipset is smaller, presumably entailing some changes in the board itself; (2) the graphics processors integrated with the board are similar but not identical; (3) the later model has a Thunderbolt 2 port while the earlier one is a first-generation Thunderbolt port. I found this info on the Everymac comparison page. Just my opinion but if it were me, I'd probably just look for a larger RAM/memory board from the same model. Macs are notoriously finicky and I wouldn't be surprised if the Thunderbolt mismatch crashed the system even though in theory it shouldn't.
由 tthorntonuhl 完成的
I think you've jumped to far ;-}
As long as the connections (keyboard. trackpad, etc...) to the logic board are the same between the logic boards the chipset used on the logic board does not matter.
由 Dan 完成的
Yes I did jump too far, and I am honestly glad to be proven wrong!
由 tthorntonuhl 完成的
显示更多的1条评论
