跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
iPhone 6s shuts off at 80%
Just replaced iphone 6s battery with ifixit iphone 6s battery replacement kit and guide. I followed the instructions including draining battery and charging it fully. The iphone shuts down at about 80%. It will not turn on until it is plugged back in to a power outlet with the apple charging cable.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
its possible that the battery just needs to be calibrated but after a few charging cycles and the problem is still there i would consider contacting Ifixit and letting them know and they might send a replacement battery.
这个答案有帮助吗?
得分 1
2条评论:
When you say that the battery just needs to be calibrated, do you mean just try to drain the battery down to at least 10% or lower then charge 100% and do this a few times. I just replaced the battery last night and only calibrated it once.
完成的
Charge the battery fully and the discharge it completely. do this a few times and if the problem still persists then i would contact Ifixit for possibly a replacement battery.
完成的
添加一条评论
If recalibrating the battery does not work, try restoring the iphone as new. If you are still having problems with the phone after restore, I would try contacting iFixit and see if they will give you a replacement battery.
这个答案有帮助吗?
得分 0
添加一条评论
I have erased all contents and setting on the iPhone and restored back to factory settings. The iPhone was still shutting off and I needed to plug it back in to start it again. I checked the battery with Coconut Battery and it still read that it is functioning well and fully charged. I then tried to see if the phone would power off if I kept the screen on and started the stopwatch. It stayed on. I then realized I needed to turn off auto-lock. Settings>Display & Brightness>Auto-Lock>Never. So far this seems to work. I was so frustrated and almost opted to just buy a new iPhone, hopefully this resolves the problem for good.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anthony Serna 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 1,212
