Soldering Temperature for Charge Port Replacement
Anyone know the temperature I should use for soldering the charge port on the motherboard? I purchased a soldering iron and it has a temperature control. I do not want it to be to hot as it will damage other parts and the board itself, then if it is to cold the solder connection will not hold.
The temp dial goes from 200-450 °C
Thanks
