跳转到主内容
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
Why is part of my screen black?
Part of my screen is black-blocking numbers-, what is the problem and how can i fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
8条评论
Are the pixels dead? Or just not working while calculating (working when graphs are drawn).
完成的
@ulees Everything in the calculator works, i just have a big black half circle sticking out from the side of the screen that’s blocking numbers
完成的
@summerrose Is it dead pixels or something between the glas?
完成的
@ulees i actually don’t know, what would be the solutions for both problems?
完成的
@summerrose There is one solution for both problems and it's warranty. If you don't have it then there isn't solution for dead pixels problem. If it's something in the between of screens you can teardown your device and try to remove it. I doubt that is the last one.
If this helped please let me know so i type a full disclosure in answers tab so people can find it easier .
完成的
显示更多的3条评论
添加一条评论
1个答案
已选择的解决方案
Hello,
so me and OP of this post resolved the issue in the comments so if you don't mind reading all that.
If you are a little bit lazy just read the last two it contains it all.
Thanks.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Summer Rose 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 22
总计 3,536
