跳转到主内容
加入维修社区 - 创建账户
What part is this?
Since I need to change my speakers (no sound when turning on the laptop and low volume) today when changing the fan I found this piece but i don't know what is (like a bottom on the left of the fan)
Thanks in advance
Update (01/08/2018)
Hi @danj hope I'm not pointing just at the left speaker.
Anyway this image show better the part which in some way is not wrapped.
Update (01/08/2018)
OK guys Just had a bad day.... I was pointing out at the subwoofer that in fact is usurated due the hot.
Thanks anyway I just need to find a solution to purchase in Europe quickly the parts!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Can you give us a better image and point to the part you have a question on.
Just below the speaker (black) is the optical drive (silver with clear plastic cover) is that what you are wondering about?
完成的
添加一条评论
2个答案
已选择的解决方案
Here is the IFIXIT guide to replace the Right/Sub Woofer speaker MacBook Pro 13" Unibody Mid 2010 Subwoofer & Right Speaker Replacement and here's the US IFIXIT part: MacBook Pro 13" Unibody (A1278 Mid 2009-Mid 2010) Subwoofer and Right Speaker IFIXIT also has a European site: IFIXIT Europe I don't see the part listed but they still might have it. Post a message to double check. Otherwise the Bookyard in the UK has the part Unibody MacBook Pro 13" Speaker & Subwoofer - Right (used) Apple P/N 922-9057
Replace a subwoofer, right speaker, and cable compatible with the model A1278 Mid 2009 to Mid 2010 MacBook Pro 13" Unibody laptop. Fix issues with sound output. Part #922-9057.图片
产品
$19.99
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Hello,
speaker replacement is covered in an how to guide by ifixit employee from step 22 and to the end.
Here is the article: MacBook Pro 13" Unibody Mid 2010 Left Speaker Replacement
这个答案有帮助吗?
得分 1
4条评论:
@ulees thanks for the vid, I'm in Europe and I don't like new macbook so I'm waiting for the 2018 line, today i got an ssd card, 8GB ram, but I must fix audio.
Sadly in Europe ifixit doesn't have left and right speakers, so I must order in USA.
完成的
I'm from Europe to I hope the speaker isn't expensive so you don't have to pay the customs.
Also mark this thread/post as solved.
完成的
How i can set the question as solved?
完成的
You already did. Dans answer says chosen solution.
完成的
添加一条评论
添加你的答案
James Dean 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 18
总计 190
