跳转到主内容
Produced by HP, this Energy Star laptop has a 11.6 inch display, a 360° hinge, a touch screen, and a quad core processor. This laptop can be identified by its model number, m1-u001dx.
6 个问题 查看全部
Can I fix my laptops on button myself?
I was cleaning my the in side of my laptop and accidentally knocked something off. I checked and it's the little button that serves as the button that turns the laptop on. I have pictures of the button I knocked out https://m.imgur.com/lDocLRt
http://imgur.com/WWf055w
Can I fix this myself or should I get it repaired by a professional?
[Edit] If you need more pictures I can give them.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Yes, you can repair it:
1) You should have the tools.
2) You need to be very careful because if you're not, you can mess up other things.
3) You need to have some medium soldering skills, because probably you will need to perform a SMD (Surface Mounting Device) soldering, and that is not as easy as you may think.
I recomend you to practice with some other things like old radios or some china cheap electronics (you can use them for practice if the components don't have a little metallic stick that passes through a hole because that is through hole soldering (you may not see little sharp soldering points) and you need ALL the tools)
I recomend you to ask a friend with soldering skills to do that because you should not practice with your pc motherboard.
Also, if you will do it, I recomend you to look tutorial videos of SMD soldering.
Greetings, Koxx.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Aron 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 107
