跳转到主内容
加入维修社区 - 创建账户
Inexpensive 5 1/4" 4G LTE 2016 phone. Fixed battery, 2 SIMs, up to 64GB microSD.
Why can't I change the screen orientation from portrait to landscape
When I turn my phone sideways it doesn't change its orientation at all. Only time it does is when I click full screen on a YouTube video. While I'm watching the video, I cant turn it back to portrait unless I leave the app.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I recently came across the same problem. Same thing with YouTube, only time it goes to landscape. There is no “auto screen rotate” option in display, accessibility, or where I thought it was, in the drop down settings with like flashlight and wifi. I never changed any settings, that im aware of.
完成的
添加一条评论
2个答案
已选择的解决方案
Hi ,
Have you checked that the screen rotation setting is enabled?
Go to Settings > Display > Rotation and enable auto -rotate screen
这个答案有帮助吗?
得分 1
添加一条评论
Hi @Scott Pauley,
What is the make and model number of your phone if not a Blu Life One X (2016).
If it is a Blu phone, try starting the phone in safe mode to see if you can get screen rotation. (method should be the same for all Blu phones and a lot of other makes).
If you can, then a downloaded app is the cause of the problem. The trick is to find out which one. You need to uninstall each downloaded app, one by one, and test the phone in normal mode, between each uninstall until it works. The last uninstalled downloaded app will be the culprit.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Juwan “ClueGamer15” I 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 25
总计 7,729
