跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iPhone 6 Searching / No Service
Hey, My 2 year Old IPhone 6 cannot seem to get any service I have tried the drop method which does work But only for a small period of time .The phone recognises when the sim is in or out of the phone ,I cannot get the imei number when I call *#06# But can get it in settings. The phone previously had problems with The Touch ID and Charge IC On the motherboard Randomly Breaking and not working but I got them repaired.If anyone has any idea what this is Please let me know ,
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
This is an issue with the logic board relating to the baseband chip area. You will need to take it to a micro-solder to fix.
这个答案有帮助吗?
得分 2
3条评论:
How does this Chip just break by itself for so many people and why does it sometimes work when dropped?
完成的
This occurs because most of the major chips on the logic board on iPhones are BGA mounted (ball grid array mounted) meaning they basically sit on an array of solder balls. Also the design of the phone is pretty thin.
This is vulnerable to bad solder joints that break with lead free solder and as you know the iPhone 6 frames bend too easily which can make this issue occur easily.
完成的
For the OP...additionally, there are two copper traces underneath the Baseband IC that tend to crack from all of the drops, impacts, flexing and twisting. These have to be solidified.
完成的
添加一条评论
Place the non-original chip (ie, a chip other than the bracket on which the device is locked) and connect the device to iTunes through a USB connector. When the device is detected by iTunes, back up and select Restore. (Try restoring without holding Shift / Option, or place the iPhone in DFU mode to do this.) After the restoration process, you will have two options: Restore from a backup and Setup iPhone as a new phone. Choose the second option. After selecting the second option, you must skip the activation steps. After the completion of the activation steps must appear (if nothing happens, repeat the steps)
这个答案有帮助吗?
得分 0
添加一条评论
Also, There is something thing loose inside the phone if that has to do with anything?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aaron Clarke 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 4,148
