跳转到主内容
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 个问题 查看全部
Cracked Screen on Phone
Hello,
today my phone fell and my display glass broke (Samsung G. S3 Neo), the display normally works, but I have a big crack there. I do not want to put my phone in the repair shop, so I wonder if it can not get worse or something, and that the display will stop working.
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
There is always a risk of the LCD or the digitizer breaking a short time after the glass. It may be best not to press your luck, back up the phone, and purchase a replacement.
这个答案有帮助吗?
得分 1
添加一条评论
eseesntially, that depends on how you handle it.
yes, the display can get worse. depending one if you put pressure on the screen, or drop it again. The crack will impose what is known as the "notching effect" and cause issues. that doesnt mean it will though. if it is handled with care, it shouldnt get worse.
这个答案有帮助吗?
得分 1
添加一条评论
You will need to replace the front glass. Check this out, it should help: 三星盖乐世S3前面玻璃更换
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
VNTG WTSK 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 78
