跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
773 个问题 查看全部
New battery seems poor quality
I just bought a new ifixit battery for may macbook and installed it accoring to the ifixit manual. When starting up after the install everything seems ok, but the new battery drains quickly. When using a batterytool (coconut battery) I saw that the design capacity is only 26% (see attached image). I assume this is not normal. What should I do to to get this fixed?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
Rob, it appears you received a faulty battery. This can happen from time to time so just give a call to the ifixit team and I'm sure they'll help you out. Or you can send them an email but phone calls tend to get you a replacement in a more timely manner.
Phone support: http://help.ifixit.com/article/135-conta...
Email Support: http://help.ifixit.com/article/136-email...
这个答案有帮助吗?
得分 1
3条评论:
Did they ever replace the battery for you?
完成的
I personally do not order batteries from ifixit, but the method to follow would be to contact them for the replacement.
完成的
Yeah. I had to reset something (don't recall what it was), but after that reset everything was ok.
完成的
添加一条评论
添加你的答案
Rob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 342
