跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
Missing resistor for home button iPhone 5
Hi,
I had to check the motherboard of my Iphone 5 after home button problemes
The BGA U3 resistor is there but i noticed one resistor close a connector(i don't know how it called ) is missing.
As you can see on the pic , one in the middle of the 3 resistors vanished.
Where can i get a free schematics for an iPhone 5, so i can get the correct resistor value ?
Which are the other possible ways to get the probleme fixed ?
Home button actually works with some pencil's graphite but Iphone can't be shaked and has obviously to be steady.
Can a soldering dot fix it temporary ? Where to buy this component ?
Sorry for my poor english and thanks in advance for help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
The missing component is a ferrite bead (FL5). It's specs are 120Ohms / 210mA / 01005. You can find them at Digikey.com under the following part number (445-8668-1-ND). It's the same component as the backlight filter.
这个答案有帮助吗?
得分 3
3条评论:
Thank you , amazed with this fast professional reply. Unfortunately i have to find another solution because cost shipping are too high for France. Thanks again for this reference , it was so difficult to find .
完成的
If a micro jumper is okay , is it possible to solder any resistor since the size is same as the missing one and no matter the value ? Thanks advance for answer
Thanks in advance .
完成的
No, you shouldn't put a resistor in place of a ferrite bead. They have different functions. A micro-jumper is okay for testing purposes.
完成的
添加一条评论
yes this is possible to repair, you can either get a resistor from a donor board, and solder it on using a hot air work station or fine soldering tweezers, alternatively as it is a resistor you can just use a small jumper wire method. We repair these all the time, it is easy if you are experienced in micro soldering. Hope this helps.
这个答案有帮助吗?
得分 1
2条评论:
Thank you very much.
Can i ask what is a "small jumper wire method" ?
I am not a big experienced in soldering but in think i can make a "dot", a "jumper wire" sounds different .
I was thinking that if a dot of graphite can make miracle, a solder dot can too. Thanks
完成的
i dont think a solder dot will be a good idea, you want to make a micro jumper between the two points, if you are unable to perform such a task, i dont mind doing it for you, i specialise in micro soldering
完成的
添加一条评论
If a micro jumper is okay , is it possible to solder any resistor since the size is same as the missing one and no matter the value ? ( here a 01005 resistor)
Thanks in advance .
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marfr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 7
总计 255
