跳转到主内容
The second generation of Citroen's supermini car was produced between 2009 and 2016.
7 个问题 查看全部
Why is my gearbox faulting?
I have a strange, intermittent issue, where my car (auto) fails to shift gears within the first 5 minutes of driving, but only during specific conditions. When it fails, there is a lurch forward, and a Gearbox fault digital warning appears. The SERVICE lamp also turns on. All I have to do though is pull over, and restart the engine. None of the warnings come back on, and the car doesn't experience a fault after that.
The problem: My car's gearbox faults
The conditions:
  • Cold, or just warmed up engine.
  • Going up hill
A mechanic has suggested I need a new gearbox - but I'm not sure it's specific to the gearbox itself. Before I spend a bunch of money on a new gearbox, does anyone have any ideas about what this is or how to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
For anyone with the same problem. Sounds like it could be this: https://www.citroenc3owners.com/c3-autom...
完成的
Hi did you find the problem I have this exact same issue?
完成的
添加一条评论
1个答案
I needed to change the item below "clutch Actuator" The price is in Dansh Kroner - that solved the problem
LL90118 Slavecylinder, kobling Actuator 1 Stk. 3.399,00 3.399,00
Good luck and happy new year :)
Jan
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hannah G 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 20
过去 30 天: 50
总计 3,041
