跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
iPhone 6s Touch ID working, normal home button is not
Dear Geeks,
I have done a few repairs back in the day, but im not totally up to date right now. However, I did some research but cannot find an answer for my iPhone. So here is the question.
I accedetially dropped a few water drops around the home button of my 6s. I already replaced the screen before, so its not water resistant anymore. After that, the normal 'go to home' function of the iphone did not work anymore. The touch ID works perfectly though. I have red somethings about splitting the home button on a 6 model, but I am working with an 6s. So now; can I fix the homebutton and keep the touch ID?
Kind Regards,
Badslipper (NL)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Dear Minho,
Thanks for your answer. I understand what you're saying but what is IPA 90%? I guess its not Indian Pale Ale as I know that as an IPA :) Hope to hear from you soon.
Kind Regards
完成的
添加一条评论
1个答案
已选择的解决方案
If you're lucky, only a small amount of water got in and it stayed localized around the HB. Open up your phone and inspect the inside to see if the Water Indicator stickers are red.
Also check to see if there is any water residue or corrosion around the HB area. There might be a bit of corrosion that is impeding the actuator. You can try to clean it with IPA (>90%). Unfortunately, you cannot replace the HB and retain the Touch ID functionality. If that is important to you, you need to go to Apple for that service.
这个答案有帮助吗?
得分 3
1条评论:
IPA - Isopropyl Alcohol
When it's 70%, it's also refereed t as rubbing alcohol.
完成的
添加一条评论
添加你的答案
Guus 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,476
