跳转到主内容
Also sold under the GMC Sierra and VIA Vtrux names, available in the US, Canada, Mexico and other countries around the world.
81 个问题 查看全部
Won't hold charge overnight!?
So I come out to my truck I have not started it in about 3 days and it won't start I replaced the water pump the alternator and put in a new battery now my truck runs great but only for a day it it doesn't hold the charge overnight I've had to jump it every morning any solutions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi,
Use a DMM's (Digital Multimeter) Voltmeter function to test if the battery is being charged at the correct rate.
Start the engine and connect the meter across the battery terminals. You should measure between 13.8V -14.2V DC to keep the battery correctly charged.
if it is not between these values check the alternator (or more correctly the regulator) which is in the alternator. If it is a "new" alternator take it back to where you got it from.
Be careful as the engine is running.
完成的
Otherwise, take it to Sears or Autozone after a jump, and they can check your alternator for you for free.
完成的
添加一条评论
2个答案
已选择的解决方案
Hey there Justin it sounds like you have a paracidic draw this video is an excellent guide to understanding what it is and how to find it
https://www.youtube.com/watch?v=KF1gijj0...
This should help
这个答案有帮助吗?
得分 2
添加一条评论
Not 100% sure, but I have a few things you could check.
1. Have you checked your voltage on your battery connections while running and not running to ensure your alternator is charging?
2. Do you have anything plugged into the cigarette lighters/ power jacks on the inside of the truck over night? Aftermarket stereo installed? Radio unit, amplifier, or subwoofers?
3. Alternator: Brand new or refurbished? Sometimes refurbished units can be bad.
这个答案有帮助吗?
得分 1
2条评论:
It's a new alternator, I found that the plug to the alternator wasn't fully plugged in when I was working on It today...im gonna see what that does in the morning hopefully I don't have to boost jump it
完成的
Hi Justin,
Don't know your vehicle but is the battery warning light on the dash coming on when you turn on the ignition (before you turn further to start the engine) and then turning off when the engine starts?
Just to make sure that you get the warning if there is a problem.
Also if you do a lot of start/stop engine driving i.e. short trips, it might take a while for the battery to come up to full charge.
完成的
添加一条评论
添加你的答案
Justin saffold 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 12
过去 30 天: 40
总计 6,124
