Need s7 replacement antenna.
“I'm trying to find a replacement antenna for my s7. No luck so far.”
这个答案有帮助吗?
Is that basically the antenna itself? I guess I was mistaking looking for the antenna module. My signal was intermittently dropping completely, for long periods. . Tried all the possible fixes.
Those are just the antenna cables that provide the connection from the logic board to the charging port dock flex daughterboard assembly.
The physical antennas are on these parts which are connected via pong spring connectors on the top area of logic board and the charging port daughterboard.
This is for the charging port area:
[关联产品丢失或禁用: IF329-024]
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 12
总计 965
