跳转到主内容
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 个问题 查看全部
Why does my screen flash and go black when I try to wake it up?
When I try to wake my galaxy s5 using the home button or the wake button, the screen will flash white, then show lock screen very briefly, then go black, but the screen is on(responds to touch) because my soft buttons on either side of the home button are illuminated and I can swipe the screen and it will unlock even though display is black.
I usually have to keep toggling sleep/wake button until if finally comes on. The problem seems to be getting worse as it is taking more and more toggling to get the phone to display normally. I fear it is just a matter of time before it never wakes up again...
I should also mention that the phone is over 2 years old and although I always keep it in a case, it has been dropped many, many times.
Any input as to the cause/solution to this problem would be greatly appreciated.
TIA
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The screen needs to be replaced as the LCD display has become faulty from being dropped too many times.
Might be too much to replace the screen depending on where you are.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ronald Clement 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 828
