跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
773 个问题 查看全部
Fixing Sticky or Crunchy Keys?
The keys on the left side of my Mid-2015 MacBook Pro have gotten to where they stick or make an odd crunching sound when pressed. It doesn't happen consistently and there doesn't seem to be a pattern to it. The keys work just fine, but I'd like to get it taken care of before passing the machine on to a friend when I do an upgrade in a few months.
Is there something I can do at home to clean/fix this issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
As to WHY, I've got suspicions that someone spilled something on it, but I legit don't know who or when it happened
完成的
添加一条评论
1个答案
It is highly recommended to replace the key board. On some models you can pop out the individual keys, but it is very hard and risky as to the plastic clips can or will break if not done carefully. If you are not very tech savvy, i highly recommend to take it to a professional to have the keyboard replaced as this requires nearly a complete dissemble of the device/mac.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
DantePD 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 2,460
