跳转到主内容
加入维修社区 - 创建账户
D1760-2 DECT 6.0 Cordless Home phone with caller ID.
How do I activate/program answering facility
How do I activate/program the answering facility
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
When someone calls and I do not answer they get a message my answering machine is not set up. How do I set it up properly in order to activate it?
完成的
Hi @paulette ,
Please confirm the make and model number of your phone?
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
Try the following:
1. Press the Message/Mute button
2. Press 8 or the talk button
3. Say your message
4. When finished speaking your greeting, press 8 or End button.
You should hear a confirmation tone followed by the greeting you just recorded.
For Record Time:
Press Menu & Select "Answ. Setup" then select "Record Time"
Scroll to the desired setting (1min, 4min, or Announce Only).
Press the OK soft key or Select (depending on model). You will hear a confirmation tone.
For Ring Time:
Press Menu & Select "Answ. Setup" then select "Ring Time"
2) Scroll to the desired setting (2, 4, 6, or Toll Saver).
3) Press the OK soft key or Select (depending on model). You will hear a confirma
Update (12/31/2017)
Hi,
Not sure of this, but do you get a "delete" option if you press the End button again after the message has been replayed following the recording of the answer message?
这个答案有帮助吗?
得分 1
1条评论:
Thanks for you're assistance. I need to erase a previous message as both ( new and old)messages are coming thru at the same time.
Michael
完成的
添加一条评论
添加你的答案
Michael Chircop 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 1,444
