跳转到主内容
Why is my new Hard Drive not seen by Disk Utility?
I wish to replace the fully working 120GB HD with the upgrade 320GB WD3200BEVE drive to gain capacity.
When I fit the new blank HD, fresh from WD, and boot from a system DVD, the HD is not seen by System Profiler or Disk Utility.
I have used the same HD cable and this is the second drive with the same problem. If I refit the 120GB HD the machine works as normal.
I have checked for Firmware updates, there don't seem to be any for this machine.
Any advice please?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Well I fixed my own problem.
The previous owner was a tinkerer like us, and had fitted an HD ribbon cable which worked with a 120GB HD, but not with a larger drive. It may be faulty, or from another model. When I fitted a different cable 'borrowed' from another PB the new 320GB drive was seen as expected.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Cameron 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 895
