跳转到主内容
GSM version of the fourth generation of iPad released November 2, 2012. Model Number A1459 / 16, 32, or 64 GB
43 个问题 查看全部
no wifi greyed out.
I have an iPad 4 GSM and the wifi and bluetooth switch is greyed out. the iPad has never been dropped or been exposed to water. It is in pristine condition. I tried a method of placing the iPad in the freezer for 15 min and when i took it out, the wifi and bluetooth started working again. Unfortunately, it was only a temporary fix. What should i do to fix this myself. Is it possible to find the exact wifi chip and replace myself. Any help would be greatly appreciated. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello!
It seems that the IC in charge of that task (usually wifi and bluetooth are going right) is damaged or is "separating" from the motherboard. The only solution is to change it (I do not advise reflow)
You need a technician specialized in that type of repairs or it will hurt more than repair. It is a delicate repair and you need tools and many hours of training to do it. I advise you to look for a specialized technician in your area or request a quote from a partner of iFixit.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Richard Rivera 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 180
