跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
Replacing the Digitizer - What adhesive to use?
Long story short, I have scratched the plastic screen on my Nintendo Switch.
I discovered that there are replacement digitizers on eBay and Aliexpress available already. However, it seems that all of them do not come with adhesive preapplied.
Does anyone know what type of adhesive is used inside the Nintendo Switch that is glueing the digitizer onto the housing?
Thank you very much in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
3个答案
最有帮助的答案
I purchased a set off of Amazon that came with "tools" and a roll of 1mm double sided adhesive tape. You would just lay a strip down and then pull of the non stick side. Pretty easy to use. The tools is comes with are pretty useless though (bad screwdriver, and doesn't have tri-wing screwdriver).
https://www.amazon.com/KR-NET-Screen-Dig...
这个答案有帮助吗?
得分 1
添加一条评论
Only 1 mm, isn't it too little ? Some recommend 3M but never precise the width.
这个答案有帮助吗?
得分 0
添加一条评论
Yes It Is Too Little, Had To Order New Strips, Don’t Know What Size yet.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
[deleted] 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 55
总计 8,556
