跳转到主内容
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
192 个问题 查看全部
My system won't turn on and charges for 5 seconds before disconnecting
I wanted to play my 2ds for something to do however it doesn't seem it wants to cooperate. I plug the charger in with the orange led turning on for approximately 5 seconds. I've been constantly plugging in the charger to have it gain charge but to much disbelieve it is still yet to turn on. If anyone has had this problem and knows a possible solution could you possibly leave an answer. If there isn't a solution and a new one is need please leave an answer.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
3条评论
Are you using the original power brick and cable? Using a too high power brick can prevent it from charging to protect itself.
完成的
Yes I'm not using anything other than the one bought with the product
完成的
Hi,
I assume your 2Ds isn´t really charging. I have had the same issue, with a minor difference - during charging the led flashes only for couple of minutes.
I assumed a problem with the charging connector of the 2DS ( after 3 years of using, may a material fatigue occurs ) .
I opened the rear panel, following the guidlines from ifixit.
After opened it , I took a look at the top panel/
there is a metal spring on the power conncetor/ pressed down carefully to increase the contact pressure/ connect with charge cable/ et voila - on the screen the symbol for charging occurs.
完成的
添加一条评论
1个答案
最有帮助的答案
Hi!
Have you tried taking out the battery and putting it in again?
Nintendo 2DS Battery Replacement
Your system probably refuses to charge because the battery may already be full.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rayne Whitehead 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 383
