跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
Home Button Not Working
Hello guys i am facing an issue with home button.My Iphone 5s home button not working after i replaced the panel . i saw many tutorials and replaced the panel and i also put the old home button in new panel but home button is not working. i tried many times but no result .so is it cable problem or phone problem ?
Help Will be appreciated thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
just try to reconnect the cable. It is very unlikely that it is the Motherboard unless you ripped the connector off the board. If that fails I would just replace the button. You will lose Touch ID though.
这个答案有帮助吗?
得分 0
4条评论:
is bracket is must while reconnecting the cable coz i lost the little bracket i am just connecting the cable
完成的
The bracket that holds the home button in place? That is what puts pressure on the button. Put firm pressure on the back of the button while it is connected to the board and chances are it will work.
完成的
No not that one i am talking about the connecting cable . when we connect the cable to board people put little bracket over the connector
完成的
I have never seen a bracket that holds the home button connector in place. But like I said, just re-connecting. And no usually the bracket is just to make sure the connector doesnt pop off.
完成的
添加一条评论
添加你的答案
ch hamza 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 208
