跳转到主内容
The BlackBerry Priv is a slider smartphone developed by BlackBerry Limited. Following a series of leaks, it was officially announced by BlackBerry CEO John Chen on September 25, 2015, with pre-orders opening on October 23, 2015 for a release on November 6, 2015. It can run up to Android 6.0.1.
23 个问题 查看全部
Power button only works with pressure against back of phone.
Like the title says, if I press hard against the back cover of the phone directly below the power button the button will function normally, but the second I take pressure off it no longer works. It clicks as usual but does not turn the screen on or off. Given the Priv's nature as a slide phone, I worry it has something to do with the mechanism and that the repair may be intensive. Hopefully someone out there can help, not having a power button can be pretty annoying. I'm more than willing to give any other information that may be relevant.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
Got the issue several days ago. Gonna disassemble my phone tonight and check it.
Seems the button is on the flexible cable, so hopefully I can just resolder it to the mainboard.
However, given the nature of the issue, it might be soldering problem for a power controller chip, that would be harder.
AFAIK the problem is massive, there are few similar reports at Crackberry :(
这个答案有帮助吗?
得分 1
1条评论:
Oleg, did you find out the source of the problem with the power button? I've got the same issue and have some electronics skills, would like to fix.
完成的
添加一条评论
添加你的答案
Patrick Schmalz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,307
