跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Replacement home button doesn't work
I replaced a iPhone 6 screen & the screen/camera/Speakers are all functional but the home doesn't work at all - nothing. My client came to me with out a home button so I cannot test the original. Is the new button defective or is the software glitching out because it hasn't had a home button in a while.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
A replacement home button should function the same as a regular home button with one exception-fingerprint ID will not work. As far as glitching? A hard rest should solve the problem. Ensure the replacement is for the six.
完成的
Im getting no functionality at all - I can't do a hard reset without a home button
完成的
You can do a hard reset if you turn on Accessibility. It will place a home button on your screen. Then just find the option to restart the phone.
完成的
添加一条评论
4个答案
已选择的解决方案
I would guess the home button to be the defective part.
这个答案有帮助吗?
得分 1
1条评论:
I will change it out and see. will update. Thank you
完成的
添加一条评论
最有帮助的答案
Could be homebutton, but could also be the longflex running along the screen
这个答案有帮助吗?
得分 2
4条评论:
The screen is brand new would that make the new screen defective?
完成的
its not the actual screen but the metal plate with the ribbon thats attached to the back of the lcd
完成的
What Daniel said. If it came with the screen, then even higher chance that it does not work as it is likely a cheap part
完成的
The button was defective - replaced the button (again) and it was fine
完成的
添加一条评论
Touch ID isn’t functional after an screen repair if the home button is replaced.
这个答案有帮助吗?
得分 0
1条评论:
I’m not looking to use Touch ID - just use the button for its other functions
完成的
添加一条评论
ensure the cable on the thermal plate is working, try another cable-ensure the socket where the home button is plugged into isn't damaged- try a replacement home button know to work with the iphone six remember the touch id will not work -all other functions should.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jeanise 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 1,166
