跳转到主内容
发售于2014年春季 的一加 一拥有着5.5英寸的显示屏 运行着基于Android的CyanogenMod 12S操作系统。
110 个问题 查看全部
Bad microphone audio during calls (handfree is working)
Hi guys!
since some days I'm experimenting problems in microphone audio during calls (latest lineageOs installed). Using handfree the other peoples hear me like ever (and it works when register audio, whataspp audio message but not calls), switching back to headset, the other people hear me very very far and diturbed; so it seems not an hw issue.
This happened some years ago (and I temporarly fixed it same way).. but there's someone that know why it happen (and then how to fix it)?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
There are many low volume post on Google. I replaced my mic and problem solved. If you do this I would replace the USB port and battery at the same time. Not a bad Idea to replace the screen digitizer and glass while your at it but opt for the replacement screen that comes with the middle frame. It is a lot easier to do.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Simone Biagini 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 14
总计 68
