My MacBook Pro doesn't turn on unless it's connected to wall
Hi,
I've got a MacBook Pro 13" mid-2012 standard configuration and a strange thing happen:
- I'm unable to turn on the computer unless the mac is connected to the wall.
- I press the battery indicator button and nothing happens.
- It has a good battery
- The power button is OK
- I connect the computer to the wall and then I'm able to turn it on with the power button and the battery indicator button shows the level of charge.
- When the computer is On, I can disconnect the magsafe and everything it's OK.
- If I turn off the computer being disconnected to the wall and then I try to Turn it on, I unable to do so, forcing me to connect the magsafe and then I can press the power button and everything works.
What could it be?
Thanks.
Update (12/26/2017)
Update (12/25/2017)
This is with the MagSafe disconnected :-(
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Lets get some additional diagnostic info.
Download this gem of an app so we can see the battery and charging logic health: CoconutBattery. Paste a screenshot of the main window of the app with the MagSafe connected and a second with the MAgSafe disconnected. Paste them here in a fresh Answer so we can see.
完成的
@urzua - Did you do one with the MagSafe connected? I see two posts of the same image.
完成的
添加一条评论
