跳转到主内容
加入维修社区 - 创建账户
For 1992 the Grand Am received new body work and a revised interior. A V6 option returned in the form of the 160 hp 3.3 L 3300 V6. The 2.3 inline four came as either a SOHC or DOHC.
Lights don't work in dash or tail lights
There are no dash board lights (except check engine) no tail lights, brakes and turn signals work. Fog lights don't work either. I replaced fuses interior and under hood, still nothing. Should I replace the relays too? I don't have any other ideas
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
Are you sure that it is the check engine light and not the service vehicle light?
Here is a video to explain the difference.
If none of your lights work then you may have a problem with the BCM (Body Control Module) which would have to be checked out by a dealer.
这个答案有帮助吗?
得分 1
1条评论:
Both check engine and service lights are on. I will have dealer check BCM. From what I gather, this issue is popular one in this make and model. Also, a whole ton of different reasons for this problem. I'll just keep trying, eventually I'll get there
完成的
添加一条评论
添加你的答案
Heaven Jourdan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 287
