跳转到主内容
The SwagTron T3, released in 2016, is a self-balancing hoverboard that features LED motion indicator lights, bluetooth speakers, a built-in carrying strap, and a 5-level battery indicator.
12 个问题 查看全部
Can I replace my cracked SWAGTRON T3 shell?
Can I purchase a new shell for the SWAGTRON T3 ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
Did you buy it at Target? Black Friday? We bought 3 - two were cracked upon opening the box - both right at the join between the footplate and the fender. The third board cracked and broke in that same location within the hour. I contacted Swagtron right away (they were actually open on Christmas) and worked through the issues with them. It was time consuming to document everything on my end, but it made the process much easier. One of the associates confirmed that they had a large number of calls coming in about the same problem - at that same location on the board.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Who do I contact as I had the same issue within hours of my son using it.
这个答案有帮助吗?
得分 1
1条评论:
Contact Swagtron via the Chat option on their website or call them directly. They repaired all three boards for us as no cost. They were very helpful. I hope that the same happens for you.
完成的
添加一条评论
I have had the same issue contacted SWAGTRON and they said it was cosmetic so they won’t do anything.
这个答案有帮助吗?
得分 0
1条评论:
Was it a chip, a crack or a break? Contact Swagtron via the Chat option on their website or call them directly. You can always ask to escalate it to a manager. Send them pictures, etc.
完成的
添加一条评论
添加你的答案
Shelly 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 10
总计 852
