Notebook charger disconnects immediately
(My model is ASUS S400C, but I've not found it here.)
I've an ASUS laptop since 2015's December. My problem is, within the time, its battery was degrading and now, if I want to run the laptop, I must plugin in the charger, or otherwise it shutdowns (stops running) immediately.
By the term degrading I meant, my battery energy was getting worse, more limited and weird.
Normally, the laptop has a red light that indicates the battery charging is on.
And it's also weird. When my laptop immediately shutdowns/crashes, its red light blinks once for 1 sec'.
But my problem got worse. Right now, my laptop is immediately shutting down. I press its power on button and right after .5 milliseconds it gets off. How to fix that? Does the issue lie in the battery?
Is it possible to run w/o battery? If so, how do I remove it from my laptop structure, since it's not directly exposed?
