跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Battery issue after replacement
i replaced iphone 5s battery on drain issue.. i tested battery using 3u toool .it is 60% health.. so i repaced it.. but the problem not solved after the replacing .. the new battery drain in 3 hour use.. and a 12 hour standby... i checked the new battery with 3u tool . noted that 2 full draining is counted by 1 cycle.. i charge and discharge the battery 6 times completely but the cycle count is 3 .. why this happen???
i restore the phone usimg dfu .. but no solution the for the problem...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I think that you bought a Chinesse Battery, they are usually cheap and may malfunction...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Shuhaibu Kh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 157
