跳转到主内容
The Epson Artisan 1430 is a color inkjet photo printer.
32 个问题 查看全部
removing cover artison 1430
I have a new Artison 1430, and want to remove the side panel for waste-ink adaption. On you-tube it shows tabs to be lifted, but my model has a smooth surface so obviously is a later model, and has no tabs showing. I'm afraid a repair manual may not be up-to-date. Anyone can help?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
www.baharchap.com
完成的
添加一条评论
2个答案
已选择的解决方案
OK, it's not very obvious, but the front panel on the right-hand side is just a cover plate` which pulls straight forward for removal. this exposes the 3 front tabs of the side panel, which are easilyprised free, and that allows the side panel to be worked upwards, disconnecting the remaining tabs, and removed.
这个答案有帮助吗?
得分 3
2条评论:
Oh, I forgot: undo the centre and right-hand screws on the lower edge of the rear panel first, then prise the right-hand side of that rear panel to release the rear tabs of the side panel. This should be done first.
完成的
thanks charles. i wonder what other repair knowledge you have for the 1430, as i get really good photo prints with it. greg wheeler
完成的
添加一条评论
can someone help me i have the same artisan 1430 printer, i tried to clean the printhead by dipping it in the windex maybe too submerged, i installed the printhead started to do cleaning at some point with the printhead almost all the way to the left went off and does not turn on anymore
这个答案有帮助吗?
得分 0
1条评论:
Did you ever get this fixed? Mine won't turn on either.
完成的
添加一条评论
添加你的答案
George August 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 868
