Bass not working well on lower volume
So i Just bought the skullcandy crusher wireless and am really happy with it, hut i seem to have this one porblem, whenever i listen music on lower volume, around 25 % the bass tends to Just turn off randomly. And will only work well with the bass slider on or above 50%. When i lower the bass it works for a little While and then it Just seems to turn off, and when i push it up halfway it Just turns on again. Again this is only on lower volume, on higher volume it workshop flawlesly.
8条评论
Hi,
Does it do this when you have the charger connected and switched on?
由 jayeff 完成的
The Headphones dont work at While charging
由 Erik Bobeldijk 完成的
I bought the headphones on 2018.02.20 and I have exactly the same problem. Were you able to fix it somehow?
由 Marek mspeedo 完成的
I have the exact same problem, exactly this. Finally found someone with the same issue. Did you figure anything out?
由 J L 完成的
I bought mine just 12 days ago and I have the same problem. My return/replace period just expired and now I must go through the hassle of claiming the warranty.
Is there any solution for this without claiming the warranty?
由 Reggie Ivaylo 完成的
显示更多的3条评论
