Blank Screen, Not Recognized by iTunes
I didn't drop it and it hasn't touched water. Just randomly died and I've charged it and I've tried to put it in DFU, Recovery and everything. Still not working, iTunes won't even recognize it.
No dough that is the fault of Hardware and causes by U2 ic Because most of the iPhone have damage with such fault because of copy charger or an over charging then need.If you want further info on don`t forget to comment below.
U2 ic is that ic by which charging and power supply from battery will divided.If this ic makes function less then causes dead.
So you have to replace that ic only the solution.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 138
