跳转到主内容
加入维修社区 - 创建账户
Released August 2003. An expensive, but high-end laptop of its time.
Power won't stay on.
When i turn the power on the power light comes on then goes right off, what could be the problem.? I took out the ram and cpu and it still does the same thing. Can you help ? Tha same thing is happening with my Dell Inspiron 6000.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Plenty of things can cause the issue, and unfortunately most of this requires trial and error.
if your device is able to boot while plugged in, and battery removed, its simply a battery problem. however, you could also have a bad charge port, that is not giving current to the device, so it is not charging. You could have a problem with a board level component as well. some devices have a failsafe, that if it does not sense a fan, it will prevent itself from booting.
these are some of the more comon reasons devices wont start.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Greg Smith 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 160
