跳转到主内容
加入维修社区 - 创建账户
iPod Classic 第六代。机型型号 A1238,80、120 或 160 GB 机械硬盘,黑色或银色金属前面板。
Why does my iPod show a red "x" in a circle?
My 80 GB iPod Classic shows a red "x" in a circle and won't go into disk mode. Does that mean the hard drive is bad? It happened when I connected it to my computer and upgraded iTunes to 9. I am using Windows XP.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 19
2条评论
Can it hold a charge?
完成的
ipod not working fix x symbol
完成的
添加一条评论
4个答案
已选择的解决方案
Well, I believe you have a 6th gen, slim 80 GB iPod classic. If I am correct, iTunes 9.X (Whatever version) should be able to work with it. When a red X appears on your iPod screen, especially the 6th Gen classics, it is usually a hard drive failure. If it charges, you know it's not the battery. Try formatting it with Windows, then do a restore on it from iTunes. If that doesn't work, try giving it a good hand slap on the table (with the sync port pointing down to the table). I know this might sound barbaric, but the needle in your hard drive might have been displaced and needs to be realigned. Also, the hard drive cable that connects your hard drive to your logic board might be slightly loose. Doing this will help you connect. If all else fails, which I hope it doesn't, then I believe you should sell it on eBay or try to replace the hard drive. A hard drive for this model can be found here.
Replace a broken or damaged hard drive for your 80 GB iPod Classic with this part.图片
产品
iPod Classic 80 GB Hard Drive
$20.99
iPod Classic 硬盘图片
指南
iPod Classic 硬盘更换
难度:
非常困难
50 minutes - 2 hours
iPod Classic Hard Drive Cable图片
指南
iPod Classic Hard Drive Cable Replacement
难度:
非常困难
这个答案有帮助吗?
得分 48
101条评论:
I love the "bash it against the table" solution- it's worked several times for me. 1+ vote.
完成的
Trey you are the man!!! I bashed my iPod classic 80gb....I had nothing to lose as I had the red X and it wouldn't restart..so I read your advise and smack! Next thing it makes this noise that I'd never heard before...like a fax modem then it's good as new! You are a champion, thanks heaps!
完成的
that was CRAAAZZYYYYYY!!! my iPod was whacked out and then i did the smack on the table... it made a sound like dial up internet and then i heard a familiar whirrr of the hard drive spinning properly. YEA!!!
完成的
How should it be smacked or on what??
完成的
Trey thanks very much you are clever man i did your intruccions and work so well
完成的
显示更多的96条评论
添加一条评论
here is a "howto" video: http://www.youtube.com/watch?v=RZDYk4-kc...
这个答案有帮助吗?
得分 3
添加一条评论
somebody has to open the iPod and replace the hard drive. The cheapest way is to do it yourself and you should get away with around $70. The part is available on ebay. Here's a iPhone Repair guide on http://www.portatronics.com/guide how to disassemble an iPhone. Maybe a tech savvy friend can do it for you. If you want to pay to have a service do it for you there are third party Services such as ifixit.com
这个答案有帮助吗?
得分 1
1条评论:
Sorry Michael, I think you may have misunderstood the modus operandi of this website. iFixit offers no repair service of any kind, but rather provides well documented and photographed repair guides, as well as the parts necessary to complete these repairs. For example, relevant to hard drive failure of this particular iPod model, there is this guide and these parts.
完成的
添加一条评论
If Your iPod Displays a Red "X" Icon:
http://support.apple.com/kb/TS1463
1. Put your ipod into disk mode
If you don't know how to put your ipod into disk mode:
http://support.apple.com/kb/HT1363?viewl...
2. Connect it to your computer
这个答案有帮助吗?
得分 1
1条评论:
and what if i cant transfer it into dsik mode at all... tried 5 times now!
完成的
添加一条评论
添加你的答案
Rita4259 将永远感激不已
浏览统计数据:
过去 24 小时: 12
过去 7 天: 87
过去 30 天: 412
总计 225,869
