跳转到主内容
Repair guides and support for motorcycles manufactured by Honda.
75 个问题 查看全部
Back wheel not turning when throttle is applied
Hi ,
I'm hoping someone can help me diagnose a problem with my Honda SFX 50cc moped.
All was fine until the other day I started it up and noticed the rear wheel was not spinning when the throttle is turned. I've already checked the back wheel splines and the shaft splines and they are fine no wear whatsoever, I've had a look inside the crankcase as well all cogs are fine belt seemed tensioned, the only thing I notice without taking everything off is the compression coil seems very stiff as if its locked up.
Does anyone know whats the matter please, any information will be much appreciated!
Thank You, Jason
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hey..
I was wondering if you found out what the problem was with your scooter?
I'm having same problem..
Please let me know.
Thanks
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jason small 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,480
