跳转到主内容
The Kindle Fire, Fire, or Amazon Fire is an Android-based media tablet by Amazon with a multi-touch color display. Repair requires only screwdrivers and prying tools.
797 个问题 查看全部
Kindle fire was dropped now see half the screen w/ a line, fixable?
So the Kindle was dropped. Now all is seen is half the screen (other half of screen is white with grey lines and grey color to it). I am guessing that the LCD and digitizer need to be replace, am I correct to think this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sounds like the LCD is malfunctioning. Could be a bad part or a loose connector inside device when dropped. You can try an old repair trick....hold the device about 12" from a solid surface and drop it (display up) with the display on. This often works on iPads that have LCD issues.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Coins1321 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 1,706
