跳转到主内容
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 个问题 查看全部
问题已关闭
Can a dead backlight be fixed with a logic board replacement?
I purchased an iPad 2 for extremely cheap on eBay. The problem was that the dock connector was so broken it was impossible to charge up. It was my first time doing such a difficult repair, and I'm pretty proud that I managed to open the iPad without ripping the wifi antenna (I put like 10 cracks in the digitizer though).
I was a bit careless and lazy, and didn't use a spudger (used a flat-head screwdriver) to disconnect the lcd and digitizer while replacing the dock connector, and now the backlight doesn't work.
When the iPad turned on, it became activation locked, and I'm waiting for a 'configuration locked' logic board to bypass and get a usable iPad.
My question is: With a new logic board, will the backlight issue be fixed, or is it more likely that the LCD's actual backlight was fried and I need a new LCD.
Happy holidays guys, thanks in advance for any responses.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
look to see if you pryed any components off, also activation can be taken off by removing either a cap or resistor
这个答案有帮助吗?
得分 1
1条评论:
It's clearly a backlight issue, nothing "pryed off" should make the backlight fail. Also, that removing a resistor from the motherboard is for 3G models only and mine is a Wi-fi model
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 55
