跳转到主内容
The Motorola DROID MAXX is the successor to the Motorola DROID RAZR HD.
31 个问题 查看全部
Shows charging but then says isnt charging
I replaced a customers screen and battery on their Droid maxx 2 and now the phone shows the lighting bolt saying the phone is charging but when I go to the settings and go under battery it states that the phone is not charging and the battery percentage is not moving, can someone please help me with this issue? PS I removed the wireless charger per customers request
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
there is a possibility that the port isnt transferring the current properly. i would suggest replacing the port, to see if that works.
however, you could have a board failure, or software corruption as well. a factory reset would fix a software corruption.
这个答案有帮助吗?
得分 0
添加一条评论
If it wasn’t the battery that is busted then it means that you are using a power adaptor that is not giving enough power to charge it. I do hope that the phone is currently is working! Sorry if I came in way late.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
cellphonebuyer1 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 143
