跳转到主内容
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
281 个问题 查看全部
Replaced Retina display, but MacBook won't power up . . .
Recently replaced my early 2015 MacBook's retina display. Press the power button but nothing happens.
Have hooked it up to a 5 watt charger as indicated in one of the comments, but still no results.
Ideas on where to start on a trouble shoot?
Any ideas are welcome . . .
Will
Update (12/19/2017)
Okay! I think the display cable was loose. I reattached it and now it boots normally. Now, there is a milky haze around the border of the screen. Could this be the display cable, or should I get another retina display?
I have rebooted and adjusted display settings . . . External monitor looks fine , , ,
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
7条评论
What happened to it that caused you to replace the display?
完成的
LCD screen fell. Got cracked after falling. Still worked, but was like looking through a stained glass window. Now won’t power on at all with the new screen.
完成的
ANYTHING happen? lights? sound?
完成的
Just reopened the case. Last night, dead, no sound, nothing. Reconnected the charger and heard a single chime! At least it's something.
完成的
It unscrewed the battery retaining screw and pressed the gold LED button , then reconnected the screw,
完成的
显示更多的2条评论
添加一条评论
1个答案
已选择的解决方案
It was a display cable connection. If your MacBook won’t respond, try reattaching the display cable.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Will Rast 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 213
