When I press L2 my character moves forward
In any game I play that involves aiming I press L2 to aim my character moves forward
reset your controller the tiny hole at the back of the controller with a pin
这个答案有帮助吗?
That was the first thing that I tried. I finally disassembled the thing and shot the left stick (which had some drift and response issues) with some dielectric grease. No issues with the left analog or L2. You could probably use a different lube, but I can't comment on their effectiveness or potential problems. It could only be a temporary fix--but has held up through several hours of game play. I'll report back if it changes.
hoo nice if the problem resurrect try disassembling the controller, spray or brush the board with fuel or alcohol mostly the affected areas
note the fuel or alcohol should reasonably small amount
cheers
It's been going a week strong, no problems. A buddy used Rem oil, so it looks like that works. It only takes a tiny squirt or two in the base assembly of the left stick, so yeah--a little dab will do ya. ;)
I left the trigger alone, and the old L2 shuffle disappeared with the left stick drift.
that's excellent brother either one of those trick works :->
I got a controller that was doing that issue and I found a permanent fix to this problem. If resetting the controller does not work, the problem is related to the joystick (joystick drift). Sometimes it will just need a clean to the potentiometer and other times, you will need to change it but they are very cheap and easy to change (no soldering require). I found this video that should help you to fix your issue : https://youtu.be/RcIza5Zz8qY
这个答案有帮助吗?
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 32
总计 25,983
4条评论
I've noticed this in multiple games. Odd. An adjustable deadzone in system settings would be useful as a band-aid, but you know Sony...
由 cylentstorm 完成的 分享
My ps4 controls l2 shoots an makes me move side ways any one know wtf is wrong with my control ?
由 Ely Ramirez 完成的 分享
This is for my Xbox controller(PowerA controller) where if I press RT it makes me go forward slowly and I'm looking all over the internet and on YouTube but it says "oh that's your problem? Sorry but it's drift not this $@$* so go fix you joysticks since like this isn't a problem bruh it's drift" and no videos or google searches help me fix this $@$* and like if I can have help to fix this then i would be so happy
由 Jaxon Relle 完成的 分享
go to key bindings and reset them to default
由 Albert Einstein 完成的 分享
