跳转到主内容
The Stylo 2 (model number LS775), the second iteration of the Stylo series, is manufactured by LG and was originally released in April 2016.
81 个问题 查看全部
How can I remove unfortunately system ui has stopped working
How can I remove unfortunately system ui has stopped working but won't let me do anything else. Like log onto the phone
回答此问题 我也有这个问题
这是一个好问题吗?
得分 19
9条评论
What is the name of the app?
The link doesn't work on the computer.
完成的
The dose not work I can't download any thing or delete no thing work just the sentence unfortunately the system UI has stopped
完成的
How do I correct the ui malfunction on my straight talk service phone. It says it's stopped working and then a clock symbol says wait. It keeps showing up. I really don't wanna data reset my phone!
完成的
My Tablet RCA say “Unfortunately System Ul has stopped. What can I do?
完成的
Turn phone/ tablet off. INSTALL AN SD CARD .The Ui system stops working because it is overloaded with work, The SD card should take some of your files and apps. It chooses but you can ask it to take. more apps. When you turn phone on this process should start and Ui should be better
完成的
显示更多的4条评论
添加一条评论
6个答案
最有帮助的答案
WARNING: Use caution when undertaking this process. One wrong selection can wipe your phone.
Ive had this same phone since it came out and needed to do this once. Still kickin
  • Power off your Android device
  • Hold the volume DOWN and power button until the recovery menu appears
  • Press volume down until the word Recovery is highlighted, then press the power button to reboot into recovery.
  • You should now see a black screen. Hold down the power button and press the volume UP until you see the recovery menu.
  • Using the DOWN key, navigate until you have wipe cache partition highlighted. Press the power button to erase the system cache. Once the cache is cleared, use the volume DOWN button to navigate to reboot to bootloader, and press the power button. Your device should reboot back to the original menu (see in first picture). Using the volume down button highlight REBOOT and press the power button. Your device should now reboot into Android with a cleaned system cache and a much improved OS.
这个答案有帮助吗?
得分 7
5条评论:
None of these menus show up on sony xperia. Because it only blinked instead of something coming up at all. When I let go of the buttons it just started as normal again. Maybe it works better on android devices more similar to Samsung?
完成的
none of that showed up on my phone it just says safe mode
完成的
What if Recovery is not an option? Only have the following: Continue Power Up, Safe mode, USB debug mode, Factory data reset, Wipe cache, and Power down. Which of these, if any, should I choose. Thanks!
完成的
I'm just guessing but maybe "Wipe cache" is the same one? I'm no expert, just sounds logical to me based on the words. :)
完成的
i wipe the cache clean before my screen went blank still nothing very BAD BAD advise
完成的
添加一条评论
To get back in from the black screen system ui provides press button and volume button together.This does not solve the problem just gets you back into the tablet.
这个答案有帮助吗?
得分 2
3条评论:
Should say power button
完成的
Please explain the process that worked for you....
完成的
Screen is black how can I do setting and no display
完成的
添加一条评论
I had the same problem but now I solved it myself, it appears to me that no one talks about this method and they tell you to go to settings and blah blah blah!! They do not understand that the screen is black and cannot see anything! Others wants you to do a factory reset and cause you to lose your precious data! I have fully recovered my phone without any data loss!
这个答案有帮助吗?
得分 1
4条评论:
I don't know why but I have posted whole method but its not showing it
完成的
can you please tell me how you did it? I am having the same issue with my samsung.
完成的
My desktop is showing me that error UI has quit working how do I fix that
完成的
Sir. M having same issue pls tell me . How can solve this problem pls pls pls 🙏
完成的
添加一条评论
I had the same problem. but by trying to hold different buttons at the same time my phone restarted, and by doing that it fixed it.
这个答案有帮助吗?
得分 0
添加一条评论
only for the hard rest on power on batan and the waliam batan ap ya down open this next page enter option rest and next option no…no..no.yah yes option batan canfam batan yes rest starting……….. thanx for view
这个答案有帮助吗?
得分 0
1条评论:
I you seem like it's messing up my phone it's always cutting on and off of blinking and then cutting off all the way I'm going to black screen and making me try to reset my phone
完成的
添加一条评论
Is I you messing my phone up it seem like it's messing my phone up it keeps cutting off and on and blinking
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Stephanie Figueroa 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 32
总计 38,992
