跳转到主内容
Released March 2016, 7.0" Galaxy Tablet by Samsung.
47 个问题 查看全部
Why can't I update any apps?
My tablet does not have the Google play app on it. It is an SM-T280 I've tried doing a software update along with trying to download the app from my browser with no success. Without the play store, I can't seem to update apps, or install apps. Anyone have this problem also? Or know how to fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You likely have a model from mainland China.
The easiest away around this is to install the Amazon app store and use their store.
• go to Settings --> Security --> enable Apps from Unknown Sources.
• download amazon app store from https://www.amazon.com/gp/mas/get/androi...
• use the samsung file manager and install this apk
Otherwise, here is how to get Google Play Store.
• download http://www.apkmirror.com/apk/google-inc/...
To download each APK file, just click on the link, and then scroll down where you’ll see Download APK. Click that.
Install the above 4 files with the Samsung file manager in the following order:
Google Account Manager APK → Google Services Framework APK → Google Play Services APK → Google Play Store APK
You should see the play store on the home screen now.
All you have to do now is just tap on your new Google Play Store app, and sign in with your Google account.
You may find that it might not work at first, but it will be alright after you’ve signed in.
这个答案有帮助吗?
得分 1
3条评论:
I have tried repeatedly to download the play store app itself and all I get is a little sign that says that it wasn't installed. It worked wonderfully for the amazon app but i was really hoping to get the Google play app :( the amazon app just doesn't have some of the stuff that Google does
完成的
But thank you so much for the help
完成的
@alexf1x1t, did you install all 4 files I provided in the exact order? If so, try a a different google play apk. Apparently, there are 4-5 variations. One of these should install.
https://www.apkmirror.com/apk/google-inc...
完成的
添加一条评论
添加你的答案
alexbushell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 1,511
