跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Error 4013 iPhone 6
The iTunes will stage, 'waiting for iPhone', and then into, 'preparing software for iPhone'. I will then go back to 'waiting for iPhone' and crash, ending in error 4013! It is otherwise in a constant loop. I cannot access and settings!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 16
3条评论
1. Do a Factory Reset of your iPhone Device
2. Clear Cookies, Cache, and History from your iPhone Device
3. Reset your iPhone Device
4. Use RecoveryTool
http://bit.do/exGXL
完成的
Will this get rid of that code and make phone work with no further issues or once the error has already popped up are you screwed ?
完成的
Iphone 6 getting same error 4013. I just replaced broken screen and display ok but since getting error 4013. new part in good condition as well try almost 4 computers still same! Only thing diff is miss the metal part above the display cables. Can be cause the 4013 issue ?Appricate your help! Thank you
完成的
添加一条评论
6个答案
已选择的解决方案
Error 4013 is a board level issue that only people that have micro-soldering skills can fix.
This may involve one or more of the following:
- Removing the NAND memory chip and reprogramming it
- Diagnosing and fixing the power circuit(s) going to the baseband or processor.
这个答案有帮助吗?
得分 11
1条评论:
Check the condition of CPU power supply or components on power supply rails. Or check if the CPU is pseudo soldered or damaged.
Here we have a repair guide for fixing iPhone 7 error code 4013 for your reference: https://blog.rewatechnology.com/how-to-f...
完成的
添加一条评论
This error could be due to multiple issues, In short the error is a connection error that is telling you that there is a communication issue between the device and the PC. Here are some solution
  1. Try a different cable, preferably an official Apple Lightning cable
  2. Try a different USB port
  3. Clean out the Lightning port, lint is sometimes in there not allowing a good connection, use a pick to clean it up
  4. Try a new charging port, sometimes these port get worn and need replacement. This could be causing that error
If all of these are tried and it still doesn't work unfortunately you have a motherboard issue which unfortunately would need a motherboard repair which most often is not cost effective. Hope this helps, best of hopes!
iFixit iPhone 6 Lightning Connector Guide
这个答案有帮助吗?
得分 2
添加一条评论
Using Joyoshare UltFix can repair your iPhone error 4013 without data loss. I have tried myself.
这个答案有帮助吗?
得分 1
添加一条评论
Download Reiboot on your PC and connect iphone to pc. Then click on “Exit Recovery Mode”. Thats it.
这个答案有帮助吗?
得分 0
添加一条评论
but my iphone 6 ill still error 4013 again
这个答案有帮助吗?
得分 0
1条评论:
did you try Reiboot?
完成的
添加一条评论
i got same issue always Stuck on iTunes. Then Imyfone they help me out repair it and now working fine.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cody Potato 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 50
总计 35,458
