跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
Battery doesn’t hold the charge for long
Thank you already if you’re reading this
So I’m facing another problem with my iPhone 6s
After iOS update my battery won’t last more than 2 hours stand by or on screen use
I have already changed 2 batteries in 10 days thinking of the first battery was defective but i guess not
I have friends whose 6s working fine after the update but not sure what’s wrong with my iPhone 6s
I took my phone to nearest technician, he said that he will have to look into the logic board for some IC or something
Not sure what to do,
I have even tried restoring using all possible method ( DFU & iTunes restore )
The doubt I’m having is wether the problem is with the lastes iOS firmware or there’s something wrong with the logic board
One more thing if that helps
My phone is charging faster than usual and drains accordingly
Battery cycle is good, charges percentage by percentage no jump at all
Battery wear level is at 0% ( battery life app )
Pls help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论:
@aman did you ever get resolution on this issue? Just in the past 3-4 days, I'm having the same issue.
完成的
添加一条评论
2个答案
Well apple said that they are releasing a new update that will fix that the software that made got messed up after released and I’ve had the same issue with multiples so all I can say is wait but till the new update then the new battery will keep your phone charged all the time!
If you have any questions or concerns please comment below! Thank you
这个答案有帮助吗?
得分 0
2条评论:
I’m already updated to 11.2.1, not sure how long i have to wait
完成的
The next update will be in about a month or two but it will 11.2.2 so it will quit then.
完成的
添加一条评论
The charger is probably broken and most likely to bring to store for new one
这个答案有帮助吗?
得分 0
1条评论:
I have 3 iPhone chargers tried all three but no luck
完成的
添加一条评论
添加你的答案
Aman chadha 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 7,910
